ewide
#1 Posted : Friday, November 26, 2010 8:59:37 AM(UTC)
ewide
I bought oven 10 years ago and am getting error codes F-2 and F-3. Do you think I should repair oven or replace.? These codes may mean replace ECR and temperature sensor, is that correct? Is that a big job to install? Is life of oven extended for a long time possibly if I repair?
Thank you.
Joe / APP Team
#2 Posted : Friday, November 26, 2010 10:29:27 AM(UTC)
Joe / APP Team
Thank you.
Ewide,
The F2, F3, codes as you mentioned, are usually a bad oven temperature sensor(90-95 % of the time).
Part number: AP2023670
It's a relatively inexpensive repair, as well as an easy repair,(in most cases you can remove and replace the sensor, without using more than 1 tool and don't have to move the unit at all).
No, it's not going to extend the life of your range, but you should be fine for quite a while.
Even if you need an ERC, it's still less expensive than a new range.
Good Luck,
ewide
#3 Posted : Saturday, November 27, 2010 6:44:18 AM(UTC)
ewide
Joe,
Thank you so much. I am taking your advice and bought the part. I appreciate your help.
Ellen
Joe / APP Team
#4 Posted : Monday, November 29, 2010 6:18:38 AM(UTC)
Joe / APP Team
Joe,
Ellen
Ellen,
You're quite welcome,
As I said previously, be careful, make sure you turn the power off to the range, when you remove the temp. sensor, be slow and don't "yank" on the wires.
Good Luck,
