Trying to replace both filter sump and cover inlet on PDW7800G00SS GE. I can remove the cover inlet, but cannot figure out how to remove the filter sump - an access is being blocked from the top by the main conduit (AP3183362) and filter fine asm (AP3185355). I don't want to push any part hardly, as I can break something easily, but definitely want to replace the filter sump (AP3794336). Is there an easy way to do so or I have to detach some other parts in order to access the filter sump? Please advise. Txs.
I was able to detach the main conduit and may access filter sump directly, but still don't know how to remove it - can anyone help me with that? Or, maybe, the coarse filter should be removed first? If so, how to remove/detach the coarse filter? Any link to the appropriate doc? Any help is greatly appreciated.
