jeffct
#1 Posted : Tuesday, November 11, 2008 10:57:49 AM(UTC)
jeffct
My Roper washer now won't stop filling up!! I can unlug the unit and it keeps filling. I've tried letting it run through its cycle but it still doesn't stop. The only thing I can do is to manually put it into the "spin" mode, turn off the water supply and let it drain. I did notice that only cold water is filling the tub when I unplug the unit. If the unit is plugged in and in the start mode, the water is whatever I selected it to be on the temperature button.
Please someone help.
Thank you.
abadfish66
#2 Posted : Tuesday, November 11, 2008 11:46:28 AM(UTC)
abadfish66
You need a new water valve---->AP3094541
jeffct
#3 Posted : Tuesday, November 11, 2008 11:51:44 AM(UTC)
jeffct
I see where the intake valve is located on the back where the water lines come in. How do I go about replacing it?
