Freezer works fine. Defroster works fine because the coils are always clean. The drain hole is the problem. It always freezes up in 3 to 5 days. Drain is clean and I even put vasiline around the hole to make the water drain easily during defrost. Today someone told me to make sure it was level so I am trying that, it was 1/2 inch off. I can poor water in drain and all water drains through like always. Why is drain hole freezing up?
Where on a crosly fringe where do I por hot water down the drain hose
