front panel removal:confused:
Originally Posted by: bobets2@tds.net ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) front panel removal:confused: Bobets, Two phillips head screws in the bottom of the front panel front, you need to remove them both. Pull out and down on the front panel , untill the locator pin and the spring clips release from the washer top panel. Reverse procedure to re install front panel. Good Luck :) :) :)
