arthurwv
#1 Posted : Wednesday, November 17, 2010 6:45:43 AM(UTC)
arthurwv
I have a Maytag Dryer PYE4500AYW. It will not start and the light does not come on. I tested the thermal fuse with a multimeter and it looked liked it was fine, so then I took the wires off of it and taped them together to bypass it. I plugged the dryer back in and still nothing worked. I thought for sure it would be the thermal fuse. :confused:
#2 Posted : Wednesday, November 17, 2010 9:46:37 AM(UTC)
Replacement parts for MAYTAG PYE4500AYW Dryer - Ele | AppliancePartsPros.com
Looks like the wiring diagram included with the above is incorrect as it is for a gas unit.
First thing to check is power to the unit.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
arthurwv
#3 Posted : Wednesday, November 17, 2010 3:22:46 PM(UTC)
arthurwv
Thanks for responding. I made a mistake. I tested the the thermostat instead of the thermal fuse. The thermal fuse is no good. I will order the replacement kit for it. What is the best way to replace this? Do I have to take the tumbler out to do it?
