The compactor stalls during its cycle. We suspect it may be the motor. Is the motor powered by a relay or is it wired directly to the power source? What is the procedure for removing/replacing the motor? Is the motor accessed from the front or rear of the appliance? Can the motor be removed while leaving the appliance in place?
Hi Roman, What it does when you try to start it? Does it make any noise? Here are the break down diagrams for the Thermador trash compactor Model TMC30BGene. Gene.
