My oven heats up slow. I replaced the igniter and it still does the same thing. What should I look at now?
There are two igniters. The one you see is the broiler igniter. You may need to remove the bottom tray from the oven (it's held on with two screws the same color as the oven interior) to see it. If it isn't glowing in Preheat, you'll need to see if it's getting power (120VAC). If it is receiving power but not glowing, replace it. Part number: AP4096758
Originally Posted by: fourparkinson ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My oven heats up slow. I replaced the igniter and it still does the same thing. What should I look at now? I have already put a new igniter in the oven and it does glow bright.
