I have both indicator lights on for the top elements when all switches are in the off position. This is an electric range with expososed elements. Help. Don
Originally Posted by: homeguide ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have both indicator lights on for the top elements when all switches are in the off position. This is an electric range with expososed elements. Help. Don Don, A model number would be a great help. A guess, at this point, A shorted wire or a shorted infinite switch(s) If you can, access the control panel, and check for shorted, damaged, wires or arced damaged contacts on the switches. :) :) :)
Thanks for the follow-up. Turned out to be two infinite switches. Again, Thanks
Originally Posted by: homeguide ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks for the follow-up. Turned out to be two infinite switches. Again, Thanks Homeguide, Glad to hear you got it figured out and repaired. Thanks for the update, Good Luck, :) :) :)
