burneyk
#1 Posted : Monday, November 1, 2010 10:20:59 AM(UTC)
burneyk
I have a Kenmore under the range microwave, model# 665.6060900, my door latch is broken and I cannot see how to replace it. I ordered the part but do not see how Im suppose to get it on. Please help
Joe / APP Team
#2 Posted : Monday, November 1, 2010 3:21:28 PM(UTC)
Joe / APP Team
Burney,
I take for granted, you mean the latch on the door, not the catch / switch assembly inside the microwave.
These instructions, should get you through the repair,
Good Luck,
:cool: :cool: :cool:
1. Unplug microwave oven or disconnect
power.
2. Open the microwave oven door.
3. Pry the choke cover away from the top
door pin, and remove the top pin from the
pivot bracket. Lift the door off the bottom
bracket, and remove it.
4. Place the oven door front side down on a
padded surface.
5. Remove the choke screws from the door
frame
6. Starting at the top right corner , pry
the choke cover out with a putty knife,
and unsnap it from the choke. Only remove
the top, bottom and right sides of
the choke cover at this time. You will remove
the handle end of the choke cover
later.
7. Starting at the top edge of the door near
the center and working clockwise, use a
putty knife, and pry the latching tabs of
the choke out of the door frame slots. Lift
the choke as you release the tabs so they
do not snap back into the slots. NOTE:
When you reach the handle side of door,
pull both the choke and the choke cover
away from the door frame, and then separate
the two components
8. To remove the door switch actuators from
the choke, remove the screw from each
actuator
REASSEMBLY NOTE: When you reinstall
the door on the oven, insert the top pin into
the pivot bracket and press down on the pin
until it snaps into place
How to replace Kenmore Microwave Latch? (Microwave Repair)
by mpn68 4/9/2008 3:06:02 PM(UTC)
