rodrigo_umana
#1 Posted : Tuesday, October 26, 2010 6:54:12 PM(UTC)
rodrigo_umana
Just moved house, piped up the washer/dryer and plugged it in.
Pulling the washer select knob out does nothing.
Pressing the dryer start button does not start the dryer.
However, if the washer setting is on, pressing the dryer start button starts pouring water into the washer, for as long as I hold the button!
Any ideas? This is driving me nuts!
Thanks!
#2 Posted : Wednesday, October 27, 2010 2:24:26 AM(UTC)
Here is your wiring diagram. Your model number was short a digit, the following is for a FS2.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134769500.pdf
The way I read your post is that this was moved from the old house and ran OK there.
If this is the case I would check the wiring at the new place.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
I am assuming that you did not have to do a cord/hook-up change re. the unit was either a 3 wire or a 4 wire hook-up at both places.
rodrigo_umana
#3 Posted : Wednesday, October 27, 2010 7:28:53 PM(UTC)
rodrigo_umana
Hey thanks for that!
I found another 240 source in the kitchen and wired it across to the laundry room and now the washing machine is running normally!
Not sure what was wrong with the other connection, I don't have a proper multimeter so I couldn't test the exact voltage, just the relative difference.. so who knows.. its odd that it was making the dryer cross with the washer.. then again maybe if you make those things its not!
Anyways, thanks for the help
#4 Posted : Thursday, October 28, 2010 2:13:31 AM(UTC)
You are welcome
If you are not familiar with house wiring then I would get an electrician in to repair the line. It is probably a bad connection or a bad breaker in the electrical box.
tommy1673
#5 Posted : Monday, January 20, 2014 10:36:43 PM(UTC)
tommy1673
Power to the unit is clean. Unit is 5 years old but has never been used. Any other suggestions?
