My washing isn't filling. It will hum and I believe its the drain pump that is working. I have checked to float and switch it connects with and the switch seems to be working fine. I have taken to inlet water pump off and ran it and it seems to work fine. I can't get a voltage reading to the pump. Is this the control panel or am i missing something else. Thanks
Originally Posted by: RSC007 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My washing isn't filling. It will hum and I believe its the drain pump that is working. I have checked to float and switch it connects with and the switch seems to be working fine. I have taken to inlet water pump off and ran it and it seems to work fine. I can't get a voltage reading to the pump. Is this the control panel or am i missing something else. Thanks Did you ever get a response to this? I'm having the exact same issue.
