Icemaker was overfilling and making huge block of ice in cube holder tray... had been getting black flex on cubes recently.....determined the finish had worn off the mold and heater unit, and the teeth were no longer able to eject cubes.....so ordered a replacement......I need help on steps to swap out mold and heater unit.....thanks
Originally Posted by: TBrinduse ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Icemaker was overfilling and making huge block of ice in cube holder tray... had been getting black flex on cubes recently.....determined the finish had worn off the mold and heater unit, and the teeth were no longer able to eject cubes.....so ordered a replacement......I need help on steps to swap out mold and heater unit.....thanks I can answer my own question.....remove four screws that hold the icemaker in place....disconnect wiring harness, and you can remove the whole thing from freezer.....three screws hold the end plate in place, remove them and carefully lift the end plate out....don't turn anything because you will need to put it back the same way......there are two screws that hold the ice tub and heater in place...remove them, and the ice tub can be gently removed from the faceplate....then start putting all the parts back together.......and it works....
