Filbert
#1 Posted : Tuesday, October 19, 2010 4:23:34 PM(UTC)
Filbert
Water dispenser does not work but ice maker does work. Dual water inlet valve replaced in September 2009. No AC voltage across water dispenser inlet valve when water dispenser lever is depressed. Suspect fault is with part named: Limit switch, kit (Part Number: AP4248492). Need confirmation that this is correct part. Also need instructions on how to remove old part and replace with new part in Ice & Water Cavity.
mark pierce
#2 Posted : Thursday, November 4, 2010 7:06:29 AM(UTC)
mark pierce
How do I remove panel on ice n water dispenser so I can see what's going on up there??? Water tube out of place and spraying in several directions! Amana model #srd26vw MFG #p1315201ww s/n 9807166886......Thanks.....MHP
