Just curious if replacing the unit's faulty piece with the above mentioned replacement part cured the problem. My parents refrigerator is doing the same thing with the same attempts to fix the problem. Also, is the module the same as the solenoid? Will the above recommended replacement part include the solenoid/module? Sorry to resurrect an old thread. Thanks for any replies.
Originally Posted by: firebird ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Just curious if replacing the unit's faulty piece with the above mentioned replacement part cured the problem. My parents refrigerator is doing the same thing with the same attempts to fix the problem. Also, is the module the same as the solenoid? Will the above recommended replacement part include the solenoid/module? Sorry to resurrect an old thread. Thanks for any replies. What exactly is wrong with your parents refrigerator? What is the complete model number of the refrigerator? Gene.
It has the same problems with the other unit mentioned earlier in the thread. Everything works fine on the appliance, except for the icemaker. It will no longer produce ice. The water filter was replaced approximately 1 month ago. There was no problem with the unit until about 2 weeks after the change. The model number is ED2PHEXNT00. I checked online and found this thread. I believe it may be suffering from the same problem...or, at least I think. Thanks for your response!
Originally Posted by: firebird ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) It has the same problems with the other unit mentioned earlier in the thread. Everything works fine on the appliance, except for the icemaker. It will no longer produce ice. The water filter was replaced approximately 1 month ago. There was no problem with the unit until about 2 weeks after the change. The model number is ED2PHEXNT00. I checked online and found this thread. I believe it may be suffering from the same problem...or, at least I think. Thanks for your response! Have you measured the temperature in the freezer? It suppose to be bellow 12°F. If the temperature is fine, remove the ice maker head cover and check for 120VAC between "N" & "L" test points. Make sure the test probes are 1/2" in. If there is 120VAC then using an insulated piece of wire (14 GA), short points "T" & "H" to run the motor. Leave the jumper in for a half of a revolution and remove it. The water valve should be energized in the last half of the revolution. Post the results. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED2PHEXNT00 Refrigerator | AppliancePartsPros.comGene.
