My dishwasher is dead. I have no LEDs lit on top of the door to begin the cycle. I've pulled the front apart and have confirmed voltage to the input side of the Macrotemp control module. This is the only place I can see where voltage comes in before it's distributed to the control panel and then on to the LEDs. I assume when that part is working properly it's shorted I should have voltage on either side and/or read very little voltage when measuing across both terminals. When it breaks, it's open and I can only measure voltage on one side and/or the 110 voltage across the terminal. Am I on the right track and should replace this module or may I jumper pass it to confirm?
Thank you for all the feedback. Couldn't fixed it without you. Yes, it was the Macrotemp.
