ray ernst
#1 Posted : Saturday, October 18, 2008 9:37:32 PM(UTC)
ray ernst
What approach should I use to replace drain pump on Bosch Washer WFMC3200? I am fairly sure it is the pump that is broken since it will not pump out waste water and I found a plastic glove stuck in the pump orifice. We also smelled a burnt insulation odor and hear a humming sound when using the drain command on the control panel.
Thanks in advance for any advice before I open up the washer.
Ray
ray ernst
#2 Posted : Sunday, October 19, 2008 12:03:43 PM(UTC)
ray ernst
Well, the pump is out and will replace it tomorrow. Took off the front load door and gasket to get better access to the pump. I will also test the old pump today.
#3 Posted : Monday, October 20, 2008 9:17:16 AM(UTC)
Keep us posted.
