micro wave oven has power. light, clock, timer work but does not heat.
If it's more than ten years old or close to ten its probably time for a new one The magnatron in microwaves are only good for xxxx number of hours It's more then likely the mag. or any componant on the hi voltage end will cost more to fix than it's worth
:) Thank you for your reply. Yes , I have gotten more than my money's woth on my oven. I will buy anew Kenmore oven again. Again thanks. Aneira.Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
