AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Need help replace door spring for KitchenAid Microwave
You have been a member since:: 10/16/2008(UTC) Posts: 2
I just bought a replacement spring for the door but I couldn't figure out how to put it back in. The door had 2 springs crisscross to each other, 1 spring still intact, trying to replace the other spring using the same way but I cannot put it in place, when I compared the broken one with the new one, it seems like having opposite angle, checked w/salesman saying there was only 1 part # for the spring (#4452398). So I dont know if the microwave actually has 2 different spring or I didn't know how to put it in, can someone help me out, picture will greatly help also, thanks
Here's the breakdown of your microwave. Page 4 has the door. Model KBMC147HSS0Hope this helps a little. Nat
thanks, but my question is it seems like these 2 springs has different angle, thus I cannot put one in place, I can replace the other spring, but the one that broken is the one that has different angle and the diagram only shows 1 type of spring? any ideas?
I've never worked on one of those I only know there is only one spring for both places. I'll ask Gene to see if he can jump in and assiat. Nat
Your information on replacing the springs was very helpfull. However I could only get one of the springs to fit. The other one seemed backward-even when I put it up to the one it was replacing it just didn't look like the bend went the correct way. Any advise?
Originally Posted by: gregmilano Your information on replacing the springs was very helpfull. However I could only get one of the springs to fit. The other one seemed backward-even when I put it up to the one it was replacing it just didn't look like the bend went the correct way. Any advise? What is the complete model number of the microwave and the part number of the door springs? Gene.
Kitchenaid superba Model # KEHC309JSS06 Part#4451009
Followed the instructions and it worked like a charm. THANKS! :D
Microwave Repair
