ktlspop
#1 Posted : Friday, September 21, 2007 12:19:54 PM(UTC)
ktlspop
Our dryer will dry a load of clothers, it just takes two runs. We're assuming it's not getting as hot as it should. Any ideas on what to check? I opened the back and removed the coil. Instead of the bayonet I've seen on Kenmores, this is a series of coils. Can the temp control be malfunctioning? Thanks.
richappy
#2 Posted : Sunday, September 23, 2007 8:05:21 AM(UTC)
richappy
Pull the vent off the back of dryer and measure the temperature, should be around 145 degrees.If not you probably have a burnt wire somewhere.
ktlspop
#3 Posted : Sunday, September 23, 2007 4:41:41 PM(UTC)
ktlspop
I'll borrow a thermocouple from work tomorrow and check it out> I'm assuming it should be this temp with the dryer empty? Thanks.
