I have a GE Electric Stove that flashes an FFF code on the display board. When I've looked up that code it says to replace the Electronic Control. I want to make sure that I'm going to buy the right board before I spend the money on it.
The part number that I was able to find is: AP2632445
Is this the only part I need to fix the problem, or do I need to buy the faceplate as well? Thx
Originally Posted by: dixiedog ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a GE Electric Stove that flashes an FFF code on the display board. When I've looked up that code it says to replace the Electronic Control. I want to make sure that I'm going to buy the right board before I spend the money on it.
Is this the only part I need to fix the problem, or do I need to buy the faceplate as well? Thx Dixiedog, Yes, you are correct, the FFF code indicates a failure in the ERC(elctronic range control)and you will need part number: (click on number for more information) Part number: AP2632445
As for a face plate, unless it is cosmetically or physically damaged, you do not need a new component. Just remember to unplug the line cord from the outlet, and take your time doing the replacement of the part. Good Luck, :cool: :cool: :cool:
