emily1
#1 Posted : Friday, September 21, 2007 10:09:57 AM(UTC)
emily1
My freezer door will not stay shut. We have cleaned out the freezer completely, and this has not helped. Even if it seems to close, when we open and close the fridge door the freezer door will pop open. Is this likely to be a gasket problem?
Thanks for the help.
richappy
#2 Posted : Sunday, September 23, 2007 3:10:28 AM(UTC)
richappy
Make sure the freezer door is not sagging. Door magnetic gasket must fully mate with the metal frame of freezer. If ok, check under door for torn gasket.
If ok, you can try to re-form the door gasket with a hair dryer, then before bedtime, duck tape the door closed with the gasket pushed in further. Next morning, remove tape, door should now be ok.
If still bad, replace door gasket. You can click on model # above to get part #.
KitchenAid freezer door stuck (Refrigerator & Freezer Repair)
by willeaton 4/18/2024 7:31:34 AM(UTC)
Removal of French Freezer door on Frigidaire Gallery (Refrigerator & Freezer Repair)
by Guest 5/24/2023 6:11:33 PM(UTC)
Refrigerator and Freezer Doors (Refrigerator & Freezer Repair)
by AeroncaChief 11/5/2022 4:40:11 PM(UTC)
GE Side-by-Side freezer door dispenser leaking (ESS25LRBSS) (Refrigerator & Freezer Repair)
by dhunsing 9/28/2022 12:59:56 PM(UTC)
KBUDT4270A/02 SXS freezer door gasket (Refrigerator & Freezer Repair)
by metropical 3/19/2022 9:56:33 AM(UTC)
Refrigerator and freezer door lights reversed - KitchenAid KSCS25FJSS (Refrigerator & Freezer Repair)
Belarus blacter 3/17/2022 3:50:11 PM(UTC)
Freezer door/drawer not closing (Refrigerator & Freezer Repair)
by mwarney 9/6/2021 2:14:57 AM(UTC)
How to disassemble the freezer door (Refrigerator & Freezer Repair)
by cparke 8/31/2021 7:38:14 PM(UTC)
Broken Freezer Door Handle (Refrigerator & Freezer Repair)
by Guest 8/9/2021 11:02:12 AM(UTC)
Frigidaire Freezer Door Pops When Opening - FFHB2750TS / Effortless Glide / Under French Doors (Refrigerator & Freezer Repair)
by daved31415 1/23/2021 12:44:44 PM(UTC)
Replace water line in freezer door of GE GSF25IGXNBB (Refrigerator & Freezer Repair)
by splinke 11/24/2020 3:08:26 PM(UTC)
Freezer door opens fridge door every time (Refrigerator & Freezer Repair)
by coyote2 4/9/2020 11:14:31 AM(UTC)
Ice dispenses when freezer door closes (Refrigerator & Freezer Repair)
by wrb 5/4/2019 8:08:13 AM(UTC)
Fridge and Freezer door sag (Refrigerator & Freezer Repair)
by WLHuard 7/11/2018 11:56:20 AM(UTC)
Bottom of freezer door sticks out (Refrigerator & Freezer Repair)
by smithd441@gmail.com 6/12/2017 9:23:24 AM(UTC)
