lucky_me
#1 Posted : Monday, October 4, 2010 8:26:49 PM(UTC)
lucky_me
My electric dry work but does not have any heat meaning it just blow cold air instead of hot air. Any idea would be appreciated.
Thanks,
lucky_Me
#2 Posted : Tuesday, October 5, 2010 2:50:11 AM(UTC)
Replacement parts for WHIRLPOOL LEC7858AN0 | AppliancePartsPros.com
First check the power to the unit.
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Next I would check the heating coil (Item 9 in Section 3) should be around 10 ohms.
Then the thermal fuse (Thermal cutoff) ( Item 9 in Section 3) should be 0 ohms.
If this is blown then there are other things you should check as tyou have to find out why it blew.
