After running the Convection Oven through the cleaning cycle it will not heat. Replaced the heating element, did not fix the problem. Any advice on what part or parts might need replaced? Thanks, Mark Pawuk
Originally Posted by: Mark Pawuk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) After running the Convection Oven through the cleaning cycle it will not heat. Replaced the heating element, did not fix the problem. Any advice on what part or parts might need replaced? Thanks, Mark Pawuk Mark, Did you check the thermal fuse for a closed circuit ? Part number: AP3879224
It's on the back of the oven, mounted to the oven wall, you may need to remove the unit from the cabinet. If that fuse is open,(one shot fuse ) you will also need to check for the door closing and sealing proper, and the cooling fan is running properly. Good Luck, :) :) :)
Originally Posted by: Mark Pawuk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you for your help You're Quite Welcome,:D :D
