jonamying
#1 Posted : Wednesday, September 19, 2007 8:00:06 PM(UTC)
jonamying
My refrigerator is freezing. It is so cold in there that even the mayo is frozen. Turning the temperature dial does not help. Amy:eek:
richappy
#2 Posted : Thursday, September 20, 2007 2:20:13 AM(UTC)
richappy
Measure your freezer temperature and post.
jonamying
#3 Posted : Thursday, September 20, 2007 8:23:45 PM(UTC)
jonamying
It is 8 degrees F.
richappy
#4 Posted : Friday, September 21, 2007 12:59:03 AM(UTC)
richappy
Click on your model # above and locate the damper assembly on the fridg. left wall part # 426 Unplug connector to it and jam door 1/2 way open. This will temporarily fix your problem. Basically, if your damper door is jammed and will not move easily, you will need a new one. When plugged in and will always motor back to full open, you have other problems
If you can troubleshoot with a meter, go to web site www.*************.com/forum1/3075.html There you can get info for measuring you thermistor resistance for the fresh food section. Either you have a bad damper assembly or a bad motherboard in the back, or a bad fresh food thermistor. The service sheet should help if you find one. GE, in most cases has not supplied one. This service sheet is generic, and will not have wire color codes, but it is better than nothing!
Whirlpool refrigerator freezes everything! (Refrigerator & Freezer Repair)
by Soccergkphillip 5/13/2014 9:17:33 PM(UTC)
Americana Refrigerator Freezes Everything (Refrigerator & Freezer Repair)
by floyd3609 5/29/2012 5:58:09 AM(UTC)
refrigerator freezes, freezer defrosts, conatantly runs (Refrigerator & Freezer Repair)
by billdherup 3/26/2012 5:02:57 PM(UTC)
refrigerator freezes in the fridge side (Refrigerator & Freezer Repair)
by ZURTA 8/30/2011 6:42:53 AM(UTC)
refrigerator freezes everything (Refrigerator & Freezer Repair)
by Charles Scott 2/15/2011 7:57:02 AM(UTC)
Refrigerator Freezes (Refrigerator & Freezer Repair)
by candelida 1/6/2011 10:06:55 AM(UTC)
Fridgidaire Refrigerator Freezes (Refrigerator & Freezer Repair)
by LBsr 12/30/2010 11:38:40 AM(UTC)
Garage refrigerator freezes food in low ambient temperature (Refrigerator & Freezer Repair)
by Dave Kuch 12/24/2010 4:41:31 PM(UTC)
Refrigerator freezes up every 5,6 days (Refrigerator & Freezer Repair)
by nguyenhung77478 10/26/2010 7:45:25 AM(UTC)
Refrigerator freezes food & drinks (Refrigerator & Freezer Repair)
by Frank S. 7/7/2010 11:39:34 AM(UTC)
Refrigerator Freezes Food (Refrigerator & Freezer Repair)
by quadkellys 6/11/2009 12:25:15 PM(UTC)
freezer and refrigerator freezes too much or nothing (Refrigerator & Freezer Repair)
by borgirek 1/12/2009 2:20:45 PM(UTC)
Refrigerator freezes everything (Refrigerator & Freezer Repair)
by Susan 9/5/2007 3:33:12 PM(UTC)
refrigerator freezes fresh food (Refrigerator & Freezer Repair)
by rondawn 9/5/2007 9:29:09 AM(UTC)
