I have a kenmore gas dryer that lately takes a little longer to dry clothes and we get a strong gas smell from the dryer that gets so bad it actually lingers in the clothes so bad we can't wear them. i have a lot of good airflow, and i can see the ignitor start up and the flame is 90% blue with tinges of orange. What gives?
Originally Posted by: andy123  I have a kenmore gas dryer that lately takes a little longer to dry clothes and we get a strong gas smell from the dryer that gets so bad it actually lingers in the clothes so bad we can't wear them. i have a lot of good airflow, and i can see the ignitor start up and the flame is 90% blue with tinges of orange. What gives? I also noticed that after a minute the ignitor also no longer glows orange but the flame does stay on. Is that normal?
Andy, Sounds like the gas valve is leaking. It is very dangerous. Stop to use the dryer immediately until it's fixed or replaced. The correction is to replace the gas valve assembly. - The gas valve assembly Part number: AP3094298
thanks for the info- is there any chance it could just be the ignitor? for the price of the gas valve, its not very cost effiecient to fix it, i'd probably be better off to just replace the dryer.
Andy,
I do understand the way you are thinking but I can not imagine how igniter can cause gas leak.
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Well if igniter is week it can cause gas leak
