dwa
#1 Posted : Friday, September 17, 2010 2:42:32 PM(UTC)
dwa
Our 2 year old Jenn-Air just stopped in the middle of cooking. There is no power , no led display or anything. Checked fuse and it is ok. Am waiting to get a 20Kohm resistor to discharge capacitor before proceeding any further. Any thoughts on what would cause this besides the obvious blown fuse, not power at the outlet etc. Already checked those. Would also appreciate breakdown and wiring diagram if available. Thanks in advance. dwa
dwa
#2 Posted : Sunday, September 19, 2010 7:48:14 PM(UTC)
dwa
No ideas or thoughts on why there is absolutely no power? Any ideas?
dwa
#3 Posted : Wednesday, September 29, 2010 2:44:10 PM(UTC)
dwa
The microwave just quit in the middle of cooking. There was no power to the microwave (light, cooking, display etc). Checked the outlet and it was good, plugged into another outlet with same results -- no power. Opened cabinet and pulled fuse and it was fine. Attempted to discharge the capacitor and checked it and the attached diode. Capacitor had no juice in it when I discharged it. On checking the capacitor, there was infinite resistance no matter how I placed the ohm meter leads. Also, infinite resistance on the diode no matter how the leads were connected (diode was disconnected from capacitor and case when checked). Checked wiring from the plug to the small circuit board (power board? - p/n Samsung SN-UF11B) and wiring checked ok. Don't have wiring diagram to check out the board itself. Anyway, my understanding is that the capacitor and diode are more related to the cooking and fuse blowing that to absolutely no power to the microwave. Door switches have not been checked because again they would keep the microwave from cooking, but not from getting power at all to the display and lights. Would appreciate any information/help you can provide. Thank you in advan
dewbrizzle
#4 Posted : Tuesday, October 5, 2010 9:09:18 AM(UTC)
dewbrizzle
have you checked to see if the power cord is good? are you getting power to the board? to check fuse remove from the micro and check continuity, if you check while its attched to micro it will sometimes read it has good continuity when it is blown
dwa
#5 Posted : Tuesday, October 5, 2010 10:22:03 AM(UTC)
dwa
dewbrizzle, thanks for the response. Yes, cord checked good. Fuse was removed and checked and it too checked good. I'm trying to get a wiring diagram so I can check further, but having a hard time getting one. I'm reading there should be a diagram with the microwave, but have not found one inside the case anywhere
Frigidaire FFHB2740PS2 No Power (Refrigerator & Freezer Repair)
by mnjeepmale 6/3/2024 5:19:45 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
kenmore elite smartheat quietpak 9 control has no power (Dryer Repair)
by Guest 2/18/2024 10:39:22 PM(UTC)
Gdf520pgj2ww dishwasher no power (Dishwasher Repair)
by pbajr 8/18/2023 1:00:22 PM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE JVM1540DM5WW suddenly no power a few seconds into starting it. (Microwave Repair)
by Guest 4/16/2023 11:55:25 AM(UTC)
Fridge - No power (Refrigerator & Freezer Repair)
by Guest 1/19/2023 7:36:28 PM(UTC)
Thermador t18id900lp no power (Refrigerator & Freezer Repair)
by whosurpopi 11/15/2022 9:25:21 AM(UTC)
No power to ice and water in Frigidaire FFHS2311PFEA (Refrigerator & Freezer Repair)
by Slbno1 10/12/2022 11:12:10 AM(UTC)
lg tromm dryer no power (Dryer Repair)
by Guest 8/25/2022 8:16:12 AM(UTC)
Frigidaire FGHS2631PF4A No Power (Refrigerator & Freezer Repair)
by hpreston35 8/24/2022 2:40:22 PM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 2/2/2022 6:56:51 PM(UTC)
Maytag washer no power (Washer Repair)
by Guest 10/28/2021 12:07:08 PM(UTC)
