patmac
#1 Posted : Wednesday, September 15, 2010 5:30:34 AM(UTC)
patmac
Hi,
Before we get too far, my model number doesn't seem to come up in here. My post is for help with installing a new bottom freezer door gasket, which I purchased here. The last time I replaced it, I did it with the door on, and I just thought I would try with it off this time.
I'm unable to figure out from looking at it and the poor resolution parts diagrams that Sears has, which screws to take out. Does the top of the bottom freezer door push up and into the bottom of the hinge that the refrig door sits in? There are two screws on the bottom of the freezer door that look like they mount the door to a bracket that's on the hinge. I just can't figure out the hnge assembly where the refrig door and freezer door meet.
I realize I can start taking screws out and see what happens, just thought if someone here knew the trick to save me some time.
