Washer Seems To Work Well With Small Loads,but When You Do A Large Load Of Towels They Come Out Wet. Water Seems To Pump Out Just Fine.and Spins Really Well.do Believe It's The Pump,and Wondering If There Is Anything Else It Could Be...
You have been a member since:: 9/10/2007(UTC) Posts: 9,586
Remove front panel and check above transmission for leaking tub seal. If ok, you probably have a worn snubber, particularly if you see white shavings under the transmission pulley. If so, go to www.applianceaid.com for info, part number for snubber is AP4024495
