If the pump or motor is frozen will this keep the water out of the dishwasher? It just hums but it does not spin. Everything else seems to be working properly. Is the new pump for this unit easy to replace or should I call someone out to replace it?
I figured it out and got the motor to work. All is ok. Thanks anyway
The water is entering the dishwasher at the beginning of the wash cycle, but it is not circulating during the wash. There are no clogs. At the end, it is pumping water out of the dishwasher and into the garbage disposal.
I believe I can hear the motor running, but apparently things are spinning since no water is being circulated.
How do I fix this?
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
JCG, Eddie's problem is different. He had a locked up motor, very common for GE dishwashers. Post your dishwasher model number here.
Amana Model No.:DWA73AW MFG:P1318613W Serial No.:9908102955
That is supposed to be DWA73AW.
