dorismcdowell
#1 Posted : Thursday, September 2, 2010 12:38:41 PM(UTC)
dorismcdowell
washer fill up with water but will not wash
dorismcdowell
#2 Posted : Thursday, September 2, 2010 12:45:36 PM(UTC)
dorismcdowell
fiil up with water but will not wash
dorismcdowell
#3 Posted : Thursday, September 2, 2010 12:55:01 PM(UTC)
dorismcdowell
dorismcdowell
#4 Posted : Thursday, September 2, 2010 1:00:56 PM(UTC)
dorismcdowell
Ihave a GE washer it will fill up with water but it will not wash
#5 Posted : Thursday, September 2, 2010 4:12:41 PM(UTC)
Remove the front panel and check the in line operational fuse for continuity. The fuse location is shown in the attached file.
If the fuse is fine, check the status of the motor green indicator light and post the results.
- The fuse link Part number: AP4380189
Here are the breakdown diagrams and Replacement parts for General Electric WHDRR418G0WW Washer | AppliancePartsPros.com
P.S. I understand you are starving for your washer but multiple posts in the same thread would not do any good for you because it looks for other people like someone else already replied with a fix to the problem.
File Attachment(s):
Fuse location and diagram.doc (238kb) downloaded 5 time(s).
The signal LED location.doc (541kb) downloaded 4 time(s).
Top load - unit disassembly.doc (629kb) downloaded 3 time(s).
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
Belarus Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
