Runs For 5 Seconds; Then Shuts Off. All Other Functions Seem To Operate (clock, Display, Light, Etc.)
Is this an over range microwave? Nat
No. It's A Countertop Model
My personal recommendation is that your MW isn't work repairing. You can get one like that at your local department store cheaper than the parts to try to fix that one. Nat
thanks. i think i will take your advice, and scrap it.
William, That's very useful information to have. I've seen plenty of Panasonic made Thermador microwave units with this issue. While playing with a working unit, I found that anything I did which caused the mag tube to know not pull amperage, i.e. unhook wires from mag, removing the ground screw from inverter, unplugging cn702, etc., caused the unit to shut down. I take it there's information that runs from the inverter to the pcb board on CN701. You wouldn't happen to know what readings can be read on that harness, do ya? Thanks, KC
Copy, paste, print...
Thanks a lot William - this should really help us out in the field.
KC
Groups: Banned Users
