jasonnovak
#1 Posted : Saturday, August 28, 2010 2:44:10 PM(UTC)
jasonnovak
Today there I suddenly got a whiff of a smell I knew was something electrical but didn't realize what it was until I saw my air conditioner wasn't kicking in, it was just on fan mode.
I opened it up and found a wire from the power/speed dial to the thermostat dial had burnt and melted off at the thermostat. I cut the wire and spliced in a new end, and so far after about an hour it seems to be working fine, the connector still cool to the touch.
Is this something I should be worried about? Was it a likely a one-time occurrence and safe to keep using? Can't afford to replace it now and AC is a must for the room ... last few weeks of hot weather.
SublimeMasterJW
#2 Posted : Sunday, September 5, 2010 3:22:51 PM(UTC)
SublimeMasterJW
A lotta amp draw goes through that wire. If you made a good connection you should should be good.
