Ives
#1 Posted : 15 years ago
Ives
Worked fine yesterday, wife put a load of clothes in today and dryer never heated up to dry clothes. I read a lot of other posts,. but none of them had same model number.
Need help, hate to call service man if I can DIY. Where do I start? Thanks Ives
#2 Posted : 15 years ago
Here is your tech sheet
http://www.servicematters.com/d...0Sheet%20-%203980060.pdf
I would start by checking the power
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Dennis Stroklund
#3 Posted : 15 years ago
Dennis Stroklund
HI Denman,
i am in experienced in using this site.
Can you take a look at the post I put in the Dryer section at 11:50 this AM.
I need to head to town soon for paarts it is quite a drive and I need to get stated if I plan on getting this fixed today.
Dennis Stroklund
