Washer won't empty or spin. The motor sounds like it is trying to engage but it don't go. It will make the noise like the motor is trying to go and then when it don't go it shuts off but it will go back on again after a little while but still does nothing to empty the washer or spin.
Remove the washer cabinet and the pump (the instructions are attached) and check for a foreign objects inside the pump. The pump Part number: AP2907492
