The dryer heats when you start it for a short while and then it's like it tries to cycle back on the heat and it starts making an intermittent rattling noise and no longer heats. From what I've read, I'm thinking I should replace the coils. Any other suggestions? Thanks
:) Thanks to previous posts, I changed the coils and it is working fine. I also recommend buying the coils in a kit together. Separately they were around 27 and 30 dollars each. In the kit with the 2 coils together they were only $16 total for both!! Didn't make much sense, but I didn't argue. :)
