The ignitor(?)for the burners on the left side of the stove keeps sparking. I replaced the ignition switch under each of the knobs but that didn't stop the sparking. The sparking is coming from the small ceramic piece that sits between the burners and has a wire attached to it that connects to (?) I'm not sure what it connects to. Would appreciate any help.
If all new ignition switches did not solve the problem, then the solution is to replace the shorted spark module. It should be under the stove top panel or on the oven back panel. - The spark module Part number: AP4040929
