gbolen1
#1 Posted : Friday, August 29, 2008 8:03:37 AM(UTC)
gbolen1
I am about ready to order a new electronic control board (whirlpool part #8564544) The problem was that the dishwasher wouldn't turn on. The Normal wash cycle and heated dry light come on, but the on/off switch wouldn't work and the CLEAN status light was just blinking. When I took apart the front panel and took out the control board, I noted that the lead for the W-R was fried. My question is this, I obviously need a new control board right? but what about the socket this panel plugs into on the wire harness? That socket looks a little scorched but not bad, should I go ahead and order this panel, or does this whole wire harness with the socket also need to be replaced? If so, its a bit more complicated as the wire harness is buried in the front panel, and I need to dis-assemble the whole front of the unit, as opposed to just taking off the top control panel. Please advise, thanks gbolen
libertyappl
#2 Posted : Friday, August 29, 2008 10:42:31 AM(UTC)
libertyappl
You can replace the wireharness in the door part number
8534931, which does require disassembling the door.
Nat
RedBeacon
#3 Posted : Wednesday, May 12, 2010 3:30:45 AM(UTC)
RedBeacon
Is replacement of the wireharness necessary or can you just replace the electronic control assembly? I have a nearly identical situation.
Guest (5)
Whirlpool Dishwasher problem (Dishwasher Repair)
by Brum 11/14/2013 5:15:57 PM(UTC)
Whirlpool Dishwasher Problem (Dishwasher Repair)
by bkwcheng 8/27/2012 11:36:19 PM(UTC)
Whirlpool dishwasher Problems (Dishwasher Repair)
by captbud 8/1/2012 10:21:44 AM(UTC)
by Maytag man 9/27/2011 7:08:06 AM(UTC)
whirlpool dishwasher problem (Dishwasher Repair)
by finman 2/8/2010 4:10:04 PM(UTC)
by tb69396 8/13/2009 5:04:44 AM(UTC)
