chuckiechulo
#1 Posted : Tuesday, August 19, 2008 12:53:01 PM(UTC)
chuckiechulo
hi! i have a problem with my washer. it makes so much noise when spinning, i tried to open it and i found a leak behind on the bearing where the spinner is connected. is there a way to change the bearing or it has to be change the whole spinning assembly? what parts should i replace. the leak is on the bearing itself. thank you!
#2 Posted : Wednesday, August 20, 2008 1:28:56 PM(UTC)
Most likely the rear bearing and the spinner support are gone bad. The rear bearing comes as a part of the rear outer tub. You have to replace the outer tub and the spinner assembly. This is a pretty big job.
- The part number for the rear outer tub is AP3830512
- The part number for the spinner assembly is AP3830513
