repairneeded
#1 Posted : 15 years ago
repairneeded
I need help in knowing what to check on my gas dryer. It runs/sounds great on air fluff, but when using the heat cycles it makes a loud noise that seems to get worse the longer it runs. ANY HELP WOULD BE APPRECIATED..THANKS
#2 Posted : 15 years ago
You have to take the dryer apart and check the tumbler bearings (#30 on the diagram) and the rear drum support rollers (#24).
- The tumbler bearing kit (have to order two) Part number: AP4037304
- The drum support roller (have to order two) Part number: AP4008534
