AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer motor hums, but won't drain, agitate or spin
My washer suddenly stopped working. It still fills with water, but the motor doesn't work. It hums when I close the lid, so I don't think the lid switch is the problem. I removed the motor and visually inspected it: I don't see any burns or broken wiring. Even when the motor is disconnected from the agitator and the pump, it won't spin and only hums.
What else can I check? I don't want to shell out $130 for a new motor just to find that wasn't really the problem.
You may have a bad pin on the motor connector, just push them in further. If ok you will need a meter to check out timer and motor wiring.
Washer Repair
