AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Display is Dimming and Blinking Before Oven Shuts Down
The clock/timer display glows solid green when the oven is performing properly and counts down the time, temp, etc. However, lately the display is dimming and blinking regularly now and then the oven shuts down and leaves a garbled display. By resetting the clock/date/etc. the oven will start again but when the display starts dimming and blinking again it shuts down. Any ideas?
Thanks, Steve
Originally Posted by: Steve Birger The clock/timer display glows solid green when the oven is performing properly and counts down the time, temp, etc. However, lately the display is dimming and blinking regularly now and then the oven shuts down and leaves a garbled display. By resetting the clock/date/etc. the oven will start again but when the display starts dimming and blinking again it shuts down. Any ideas?
Thanks, Steve Is this a microwave or a range ? The model number you supplied is for a microwave. And this is an intermittent problem, does not happen everytime the unit is cooking ? When this occurs, is it when the oven is on for an extended period of time ? My first inclination would be, a defective control board, being effected by heat or time, if this seems to occur on longer cooking periods.
Microwave Repair
