I am experiencing problems with my Samnsung AW1201B, it kicks the circuit breaker on my surge protector, you can restart it after you reset the breaker. But it will kick it back off in a couple minutes of operation, the plug is not hot. I had replaced the plug on the cord. Has anyone experienced this problem? It runs fine when it does run, pushes out cool air and no motor noise.
Originally Posted by: jcamato10 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I am experiencing problems with my Samnsung AW1201B, it kicks the circuit breaker on my surge protector, you can restart it after you reset the breaker. But it will kick it back off in a couple minutes of operation, the plug is not hot. I had replaced the plug on the cord. Has anyone experienced this problem? It runs fine when it does run, pushes out cool air and no motor noise. Have the compressor "Meg" tested.
Originally Posted by: jcamato10 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I am experiencing problems with my Samnsung AW1201B, it kicks the circuit breaker on my surge protector, you can restart it after you reset the breaker. But it will kick it back off in a couple minutes of operation, the plug is not hot. I had replaced the plug on the cord. Has anyone experienced this problem? It runs fine when it does run, pushes out cool air and no motor noise. this is the exact same thing that happens to mine, did you find any help?
