RWB
#1 Posted : Saturday, August 9, 2008 10:33:42 PM(UTC)
RWB
Hi, my Kitchen Aid used to compact by lifting up once on the toe kick (step down to open) now it no longer works unless I hold the toe kick up while the plunger compacts and retracts. Everything else is working and I can not see what needs to be done to fix it. Any ideas or suggestions would be greatly appreciated.
Thanks,
RWB
#2 Posted : Sunday, August 10, 2008 5:50:43 PM(UTC)
Most likely the problem is a bad motor centrifugal switch.
- The part number for the motor switch is AP3117747
It comes with the installation instructions.
Here are the tech sheets for the Kitchen Aid trash compactor model KUCS03FTSS.
Kitchen Aid Architect KUCS03FTSS (Trash Compactor Repair)
by sternmd 1/31/2009 7:51:49 AM(UTC)
