Michael Collins
#1 Posted : Sunday, September 9, 2007 10:19:58 AM(UTC)
Michael Collins
My dryer will heat for about 20 seconds then goes out. It will occasionally come on through out a 60 minute cycle but never gets the clothes dry.
richappy
#2 Posted : Monday, September 10, 2007 4:53:06 AM(UTC)
richappy
Most newer dryers have a thermal fuze and a overload thermostat. When the dryer overheats, the overload thermostat will trip ist, saving the fuze.
Your ducting may be clogged. Remove ducting and jam a thermometer in the dryer duct and measure the temp. should be around 145 degrees. If now ok just clean out the ducting in the house. They sell a linteater brush for this if needed.
#3 Posted : Monday, September 10, 2007 9:44:17 PM(UTC)
Is your dryer gas or electric?
The model number you provided looks confusing because "DET" stays for the electric dryer and "DGT" for the gas.
Depend on the heat source it could be different diagnosis.
Dryer will not heat (Dryer Repair)
by MByram 4/22/2018 8:36:12 PM(UTC)
Dryer Will Not Heat (Dryer Repair)
by coreyhall 3/6/2017 10:18:48 AM(UTC)
Dryer will not heat or turn off (Dryer Repair)
by jesus freak 1/17/2016 2:25:22 PM(UTC)
by rwebb 12/4/2015 9:44:48 AM(UTC)
Dryer will not heat and will not shut off (Dryer Repair)
by HMH1983 9/23/2015 6:44:16 PM(UTC)
Default Dryer will not heat, timer does not work (Dryer Repair)
by gotcoffee82 3/1/2015 7:37:21 PM(UTC)
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 3:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Dryer Will Not Heat, But All Parts Test OK (Dryer Repair)
by kamera 9/6/2014 9:33:05 AM(UTC)
Roper dryer will not heat (new parts installed too) (Dryer Repair)
by xenomorphlv426 2/1/2014 8:49:03 AM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Dryer will not heat. (Dryer Repair)
by modelshop8624 7/4/2013 1:24:12 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
