I have a built in oven and the controls are working fine...in fact it shows pre heated to what ever I select but the oven is cold. I noticed that this happened after I completed a self cleaning cycle. I have turned off the oven and back on to try and clear but no luck. Someone mentioned that their is a reset button on the controls. I've turned off the oven and opened the door and removed 4 small screws from just under the control panel but I can not figure out how to get the control panel cover off? Any suggestions are greatly appreciated!:) Thanks, Leslie
