Ok this crazy dishwasher decides to not work.I took off the front panel to investigate what the problem might be and found that the door handle is not making good contact with the switch If I pull up on the door handle the dishwasher will start.My problemm is do I need to replace the switch and the handle or does it come as one complete set(handle and switch)? And what is the part number for this piece so I may order it online today.Thanks in advance for the help Model # FDB635RFS4
Ok got if fixed seems like the handle and switch come as a complete set and they even give you a new seal for the door :)
