renee.swayze
#1 Posted : Tuesday, June 29, 2010 4:11:35 PM(UTC)
renee.swayze
Dryer won't heat, ordered element and replaced and dryer still won't heat. Should we replace the thermostat and if so which one and do you know the part #.
Thank You!
Renee
#2 Posted : Wednesday, June 30, 2010 4:22:37 AM(UTC)
Replacement parts for WHIRLPOOL LER4634BQ1 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203401728.pdf
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Next check the thermal fuse and thermostats with a meter.
Guest
#3 Posted : Wednesday, January 18, 2023 3:40:17 PM(UTC)
Guest
whirlpool washer Mod WTW4816FW2 reset
Whirlpool WRF535SWHZ07 Won't Program Control Board (Refrigerator & Freezer Repair)
by Guest 7/5/2024 1:43:28 AM(UTC)
WRF989SDAM03 Whirlpool fridge making ice very slowly (Refrigerator & Freezer Repair)
by BlueWRXPride 6/20/2024 5:24:45 PM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool fridge WRF560SFYM02 (Refrigerator & Freezer Repair)
by Guest 6/15/2024 5:02:08 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Whirlpool cont. clean stove SF330 PERN6 (Oven Repair (including Ranges and Cooktops))
by bruce.kolozy@att.net 6/10/2024 2:55:08 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
Whirlpool wtw500dw1 won't fill (Washer Repair)
by Guest 6/9/2024 4:14:40 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool LA5700XTN0 won't agitate (Washer Repair)
by Kyou 6/2/2024 5:13:20 PM(UTC)
Whirlpool Flame Cuts off After 5-10 seconds (Dryer Repair)
by Guest 6/1/2024 8:00:29 AM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
Whirlpool Fridge odor (Refrigerator & Freezer Repair)
by Guest 5/14/2024 4:46:42 AM(UTC)
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
