i went to turn on the cooktop light and the bulb made a pop louder than when a light bulb normally goes out. i got a new bulb and it still doesn't work. i checked the voltage to the socket and have 2 volts all the time. nothing changes when i push the off/low/high button. everything else works fine. any idea or help would be greatly appreciated.
Originally Posted by: gm5744 i went to turn on the cooktop light and the bulb made a pop louder than when a light bulb normally goes out. i got a new bulb and it still doesn't work. i checked the voltage to the socket and have 2 volts all the time. nothing changes when i push the off/low/high button. everything else works fine. any idea or help would be greatly appreciated. Did you ever find out why this is?
