My dryer control locked is on. I have tried depressing the end of cycle button, cut power to the unit for several hours, and it will not reset. Any suggestions from here?
Originally Posted by: Help in Virginia Beach ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My dryer control locked is on. I have tried depressing the end of cycle button, cut power to the unit for several hours, and it will not reset. Any suggestions from here? I have the same problem - did you find a fix?
I have a "control locked" problem too. I was advised to replace the touch pad console, which is the front face panel with the green and red buttons. It's $200 with shipping. I followed the manuel on how to swap it out. However, the problem didn't correct. Now do I go to the other electronics board on the left side? Thanks
Originally Posted by: smcoy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have the same problem - did you find a fix? No, I was advised by someone at appliance parts pros to replace the central control unit, did that as well as the user interface and still not working.
